[Scatter] Some issues with previous scatter versions
I am testing the scatter system and I found out that if I use a scatter created by Alpha 7.2, nothing will appear on the render. You can see the objects in the viewport being scattered on top of the surface, but when you press render nothing appears.
Also the settings used in a previous corona scatter are used when you create a new scatter. So, if I changed the Scatter count to 10k, when I create a new scatter, this had already 10k as a Scatter count.
Plus there is that issue that if you change the map used for the Density using the compact material editor, 3ds max will simply freeze.
I am using:
3ds max design 2015
Build timestamp: Jan 29 2015 23:52:46
it works here so, you can already guess… scene? :smiley:
The "new created objects will have same parameters as old ones is a 3dsmax feature - try it with boxes for example, behaves the same.
:smiley: No worries. I will upload the scene tomorrow.
Here you have the scene with the “bug”.
ScatterBug.max (4.48 MB)
The freezing was already fixed in another bug report, scatter not rendering was caused by the only distributed object having selected zero frequency. After setting its frequency to non-zero value it works as expected
