Hey there.
Is there any way to scatter chaos cosmos assets along a scene using Skatter or a similar program? I wanted to do that for vegetation in an exterior rendering. However, when I do it, everything works fine, but in the final image instead of the correct models, the proxies show up with the random colors. Is there any way to do it via merging the proxies or is there another way to scatter assets without doing it manually?
Thanks.
Hi @jose_ferreira ,
On a simple test, scattering Chaos Cosmos assets with Skatter seems to work as expected. Can you provide some example screenshots/recordings demonstrating the issue? Are the proxies showing correctly with the right materials if they are not scattered?
Additional details regarding the system configuration along with exact SketchUp/V-Ray/Skatter versions will be greatly appreciated!
We fixed this issue in Skatter v1.4.21. Please make sure you are running the latest version: Lindalë
Oh, that is great, thank you! Problem solved
Can you send the file to skatter@lindale.io?
