when opening “old” scenes in the final version, the light color is always white, no matter what the original was like.
would be good if you could fix it.
Hi, could you send us the “old” scene, before re-saving it, privately? Otherwise, we can just guess what’s going on.
yes I just uploaded the scene.
Feel free to ask for further details if needed.
regards
Andreas
Thanks a lot, we’ll check it out!
MacOS 10.13.6 / C4D Studio R18.057 / Version: 3 hotfix 1 (core 3) Jan 18 2019 18:43:49
I can confirm this. All corona lights in scenes build in corona 2 stable are reset to default color (white).
Corona Light Materials are not affected.
Hey guys,
you really need to solve this problem with a hotfix, please!
my workaround atm is to open the old scene in another copy of c4d with the beta installed and manually copy the color values.
The problem is, I´m running ot of time. The beta works until 01.02.2019, so in 8 Days I am done.
Is there a way to solve this fast?
I have an issue with the lighting - in my case with just one HDRi in the scene - too. Same file, same materials, same lighting from the beta 2 and the resulting renderings with the commercial V3 are very dark and dull. I posted it here: https://forum.corona-renderer.com/ Dramatic change in lighting between Version 3 and Beta 2?
Regards
Volker
Hi, mte! We’ll figure it out, don’t worry. I’m not sure, whether you can expect another hotfix in 8 days, but the beta will actually be discontinued after 21.02.2019, which is 45 days after the release. That’s what we promised.
Hi Houska,
unfortunately the last working version is the “Beta 2 release candidate 4” from October.
So all version 3 betas have the same problem, that´s why the time is running.
I see. Thanks for that additional piece of info, Andreas. In any case, all the free versions will work until 21.02.2019 all the same.
Hi, thanks for your reply.
My version says:
Demo license active.
Activated until: 2019-02-01
It would be perfect if they work until 21.02. ![]()
Yes, this only means that you can be offline until 01.02.2019. Then your C4D will need to contact the licensing server to query for the license again. ![]()
Cestmir, you are lightning-fast!!!
thanks, for the info, that takes away the stress. ![]()
Hi Andreas,
we figured out what was causing the problem with lights, so it should be fixed in next daily build (and the fix will also be included in next hotfix if/when it comes out).
Hi Ales,
sounds great, thanks a lot!
cheers
Andreas
Hi Andreas, This should now be fixed, can you please re-test and let us know? Thx
Hey Ben,
it works with the latest daily, thanks a lot!
cheers
Andreas
