Scene converter doesn't set blur to 1.0
MAX 2026, latest vray. Bitmaps are even converted to vraybitmaps but the blur value remains at 0.01.
Unrelated but why is it so hard to select the vraycam?
I also have a few vrayproxy objects that are almost unselectable. Tried switching through their modes of display.
Works fine on my end. You’ve ticked “Reset Filtering blur to 1.0”, right? Which V-Ray version do you use?
Regarding the hard selection: Are we talking about V-Ray or 3ds Max Physical camera?Does it happen if the Camera is targeted? Also, check if the GPU Hit Test is active by running this in the script listener:
nitrousgraphicsmanager.HardwareHitTestEnabled
If it returns false, try:
nitrousgraphicsmanager.HardwareHitTestEnabled=true
See if this makes things more selectable. Or try vice-versa.
vray is 7.40.04
I mean the vray cam. It works ok now, but I guess when I work in MAX for a while, do test renders, etc. Not sure. I just have to use rect select, you know, drag the mouse to select both the cam and its target, then deselect the target, to get to my vray cam.
Yeah, nitrous returned false. I’ll try enabling it.
Blur thing, not sure. The trees were all proxies, materials are all fine, but their blur value doesn’t change with the converter.
Edit:
ah ok, it seems to work on my Evermotion models, but I have these Maxtrees models that the scene converter just doesn’t work on. You can test it in the link
Will troubleshoot it, thanks.
This model doesn’t have Bitmaps to convert (it’s already using VRayBitmaps), hence why the conversion doesn’t change the blur value.
Do you wish to reset ALL VRayBitmap values to 1? A simple script will do the trick:
for i in getClassInstances VRayBitmap do i.reference.coords.blur = 1
Or maybe you’ve sent the already converted model??
Well yeah, since this value is killing the render time, and I think it’s because pines have needle textures. Thanks for this, but I think vraybitmaps should have their blur adjusted too. Unless it doesn’t make a difference at render time. Maybe it was something else killing the render, but I think it was this.
Saying it again, just in case: The blur does get adjusted, but only if the VRay Converter actually converts 3ds Max native bitmaps to VRayBitmaps.
Using the script I sent should do what you wish, then. It could have a slight effect on render time.
