Corona Scene converter.. it does not work in macosx!!! For example, if I insert a vray material or a cine material, I do not apply any conversion… same thing for lights etc.
I tried one simple Vray 3.6 scene to convert… It converts but…
- Dome light changed to Sector light
- Area light size changed to random sizes.
in Vray it was 200x1000 (light size) in corona convert 200x600 but look like 50x100 - Material changed to default Corona materials with diffuse and reflections … which is acceptable for now.
- Camera stays with Vray cam tag.
- No Composite object ID tag changed.
Recording uploaded.
for me..after click convert ,for example an default simple advance material with a texture in diffuse channel.. the material converted have no texture into diffuse channel and have activate channel diffuse, reflection, refraction, opacity set to 0% of Mix Strenght… version of mac osx
Thanks for the feedback so far, keep in mind that it’s a prototype and that differences will be had as mentioned in the change log. ![]()
I can’t reproduce problem with area light sizes.
Could you send scene to reproduce?
Sent.
iacdxb:
Any update…?
Yes, this was fixed ![]()
In next build this fix will available.
Thanks.
Simple scene with standard c4d materials doesn’t convert, at least I cannot make it happen.
Beta 2 daily + R19, macOS 10.11.6
Thanks!
For now convertor prototype explicitly supports VRay materials only, C4D support will be ready later.
Beta 2 daily + R19, macOS 10.11.6Thanks!
Till its update… and if you are vray user, convert C4D scene in Vray (Vray material converter) and then Corona converter, helps a bit.
Where even is the converter? I have the latest build (19/4/18) but cannot find a scene converter anywhere? Thanks
Hmmm.. That’s not showing in my version… I’ll double check my installs…
OK. Fixed. I must have downloaded the installer but not actually installed D’oh!
Cheers!
