So, I have quite a big problem.
This isn’t necessarily a Corona related issue but I thought I’d consult the brains trust here first…
I have a scene (it’s only happening with 1 particular project) which crashes when I open it. BUT it crashes approximately every 6 in 7 times I open it.
I open the file, it loads, before the geometry is visible 3DS max immediately crashes. No error, no warning, nothing. I open it another 4, 5, 6 times and eventually it doesn’t crash. I can use the file as usual, although sometimes a render in IR does cause another crash.
Now, I’ve tried restarts. I’ve re-imported everything into a fresh scene. The problem persists.
The scene is quite large, but I’ve split it up into multiple xrefs - the problem remains. Almost all of the materials are converted from ArchiCAD imported files.
I’m not using any forest pack (I did suspect this was a culprit early on). I’m on Max 2021, Windows 10. Corona daily Oct-15 (but have changed the daily build multiple times through this project, and even rolled-back once with no success).
Any ideas? Thanks!
