We are rendering with 3ds Max 2025 using V-Ray 7, update 2, hotfix 2.
In my scene I’ve created a V-Ray dome light using an HDRI in a VRayBitmap to light the scene. Rendering locally is fine, but if I use DR, those buckets come out a little darker. If I send the scene to render on the network using Pulze’s RenderFlow, the images are significantly darker than the DR version, even when rendered from my machine.
The left is what renders locally, the right is from the same machine over the network. The center square is the result of rendering with DR to a slave machine.
Why does my local render come out differently than what’s rendered through DR or on the network? I’ve verified that Max’s Color Management is the same on all machines, set to the default OCIO - 3ds Max Default.
The VRay method of color management works in all versions of max.
Just set the appropriate settings in the VRayBitmap. Once you get used to it it’s not much of a big deal. Mild pain if you have a bunch of pre-defined assets. But for stock models I always want to double check the settings anyway, as they are so often wrong.
