When opening a scenes of a project the information shown on the screen is very limited. The whole interface is too small. I have not found a way to stretch the opening window wider or to widen the name-column, let me know if there is a way. Here are some improvement ideas:
The scene name column is too narrow, showing only about 18 characters, as I have several scenes with a slight variation it is very difficult to have a naming syntax that describes the content of the scene with so few character.
For the same reason it would be good to have one extra free text column where one could add some additional info about the scene
The Project name on top of the window should show the whole path to the project, as I can have the same project both on workstation and on a networks drive. Because Anima is so slooow when editing the scene over the network I usually edit the the project from workstation and then sync the project folder to network drive to allow all render nodes to find the assets. I have never managed to get the render nodes render properly if the assets are only on worsktation drive. When opening the project it would be good to be able to verify that the project is openend from right disk directly on the open screen.
Br Mikko
