Scene parsing issues (freeze unless VFB is moved)
Hi Guys,
I have 2 problem when rendering now. The first is after i press render, corona parses the scene, and when it’s done corona just stops (Smiley face stops spinning) and the current task popup disappears. In the VFB the render button is greyed out and it cannot be stopped.
The second problem is after pressing render, as corona parses the scene, it gets stuck. it doesn’t go past to the next task. it can stay in the parse scene task for hours. until i click on 3ds max and it finishes parse, secondary GI and goes immediately to start the passes as if nothing was wrong. It doesn’t happen all the time but frequent enough to be ridiculous. Imagine having to sit in front of a computer as it renders an animation to make sure it doesn’t get stuck parsing one of the frames.
anybody have a clue what’s going on here?
We have a workaround: https://forum.corona-renderer.com/ Scene parsing issues (freeze unless VFB is moved) #msg202882
Hi, which version of 3ds Max and Corona are you using? Are you using any 3rd party plugins in your scene? What is your RAM usage after the rendering is started?
I have some more questions:
Can you please explain what exactly you mean by “current task popup”? Can you share a screenshot of this?
When it is stuck like this, please capture 2-3 minidump files and send them to us. Here is a guide explaining how to do it (see point 2):
https://support.corona-renderer.com/hc/en-us/articles/4402983255313-How-to-report-issues-3ds-Max-#h_01FDY55JCQMR188S36A1F0SS1T
Hi Maru,
I’m using Max 2022 and Corona 7 Hotfix 1. Yes i’m using alot of plugins. RAM Usage is in the low 60s
I’ve added a screenshot of the rendering popup i meant. That disappears when parse scene task completes.
It may be because i clicked outside of max (on a browser or another app) but it sometimes happen when i have nothing on apart from max.
I’ll send you the minidump file next time it happens.
In regard to your second problem, the same thing has been happening to me. At first, I was wondering why parsing was taking forever, then I clicked into the 3dsMax window and the parsing progress bar completed in seconds. I’m not really sure what causes it. It doesn’t happen all the time, but often enough that I have to keep an eye on the screen to make sure it doesn’t get held up.
Hi all, I’m also using Corona 7 Hotfix 1 and also encounter the scene parsing issue Andrew and John describe. To me it seems to have to do something with Forest Pack and/or Railclone, but I’m not sure.
In some other topics on this forum I read a similar issue is fixed in the latest Daily Build of Corona 8. Is it possible to ‘back-port’ the solution to Corona 7?
Hi there, I’m writing for a similar (same?) issue. I hit render and the scene gets stuck with parsing task. The render goes one JUST when I move the mouse or click on the frame buffer. It’s a big problem when you have a long list or frames. This happen with or without backburner. Corona 7 and 3dsmax 2022 latest version. Please help, it’s really limiting. Thanks!
Hi Guys,
Are you using any remote desktop software? If so which one, and which version?
Secondly would you be able to provide me with a scene?
Instructions on how to do this can be found in my signiture.
Rowan
You may be on to something because the file I was experiencing the issue with was using Forest Pack, but not Railclone.
Hi, I was using Anydesk (version 6.06) and I found some posts here that reported problems with this remote control software… I uninstalled it and after some tests the problem seems to be solved. Hope it was just this… By the way, do you know a good free alternative for Anydesk?
Thanks very much!
It is happenning to me also.
Send the file thru backburner on another physical location thru vpn; and connect remotely thru anydesk to see the progress and It gets stuck on parsing scene, almost forever if you don’t do any click on the screen, anywhere you want.
When it finish the job, and starts another one, an unkown error on backburner appears and the task won’t start rendering and I have to restart the pc so it can start rendering again. This happens over and over again.
Using 3dsmax 2022.2 and corona 7 hotfix 1.
Is it possible to send us your backburner logs? Please see: https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-find-and-analyze-your-backburner-error-logs.html
Any particular 3rd party plugins on that scene, would it also be possible to share an archive of that scene with us?
Thanks for clarifying, we are aware of Anydesk issues.
(Report ID=CRMAX-1135)
these are the logs from the slave and manager.
tell me if that is enough to check the problem.
slave01_log.zip (217 KB)
manager_log.zip (243 KB)
Thank you very much, please stay posted.
Just to add to the discussion, I also have the same issue with the parsing scene getting stuck until I click on a window (it doesn’t matter which one) and rendering resumes normally.
I also use 3ds max 2022, corona 8 daily 21-12-06 and forest pack and railclone on a very heavy scene and I’m not limited by my pc
I’ve had this happen to most of my scenes in the last few months with the last couple of daily builds.
However I had a couple of textures missing, and I think when I created the missing textures the parsing would work.
I am running PARSEC remote desktop, Forest pro, and Pulze Scene manager it could one of them.
But fixing the missing textures helped this time, time will tell if it fixed it for good.
Yeah also have this parsing issue as well!
I use Parsec to remote work, however I’ve been using it for 2 years and never had this issue until I started using Corona 7 back in September. As everyone said, bit of a pain when you want to batch render/render frames over night…
I 'm using Parsec for a little time now (2 weeks) on corona 7 and I haven’t had any issues with parsing, but of course that’s my experience in this limited time.
My only issue with Parsec is that you have to have a mouse connected to the other system in order for the cursor to appear when streaming. I don’t think that’s the culprit but thought I’d share!
Hello!
I’m also suffering from this issue. For me Logitech G Hub is suspicious, does any of you using it?
Csaba
Hi everyone can you please try using Corona version 8 RC1 and see if the issue persists? (Build can be found here: https://forum.corona-renderer.com/ Corona Renderer 8 for 3ds Max - Daily Builds Changelog #msg196056)
Please also make sure you have your windows updated with the latest updates.
Could it also be related to DR being used ? (same scene, without DR no parsing issues, with DR parsing issues)
