Scene tab settings reset every time re-open file
Some folks in our office are having this issue where all their scene settings are reset when the open 3ds max. It seems intermittent. i.e. all the environment overrides get cleared out.
Anyone else have this issue / know a solution?
We’re on Corona version: 2
Thanks,
Did this happen with Corona 1.7.4 or earlier? It could be a 3ds max issue.
Unfortunately not. It’s showing up in v2.0
I really hope this one gets tracked down, sounds like a real show stopper with the potential to really f**k up a day.
haha pokoy! indeed!
Is there more info you can provide? Which max version, OS version etc. Also, which language localization settings are you using in your office and are those guys experiencing this using standard OS keyboard layout (dot/comma swapped for decimal separator etc.)?
Hi pokoy, it’s max 2016 SP4, Windows 7, No language localization (English out of the box version). Typical keyboard layout. No swapping of cammas and dots.
Is this happening only with the scene tab, and not other ones?
Can you share a scene where this has happened at least once? Chaos
