hi!
it’s my second time to post..
need your Comments and suggestion.. before i do the next process (photoshop)
im confused which setting, is better?? the darker one or the lighter one!
and does it look, realistic enough??
thanks so much!!
hi!
thanks so much!!
Re: schematic (residential)
the lighter one is so cool in terms of nice renderings…add some entourage for more realistic effects..good job
i think the darker one is much better…in terms that you can see the texture on the walls clearer…both’s pretty good… good job…
when will the photoshopped one be up?
gpac
I would say out of the two, the second one is better. The contrast could be increased a little in PS, but to me it looks the most realistic. I would adjust the position of the sun to give more interesting shadows i.e. so you can see shadow patterns on the elevation.
Good Luck
David
hi guys,
thanks for the comments( vhin042003,Pheranova and dcauldwell) i already finished the final composition, but unfortunately i cant seem to post it (An Error Has Occurred!
The upload folder is full. Please try a smaller file and/or contact an administrator.)
i’ll try to post it as soon as I’ve figured it out.
i figured it out already, hehehe. ;D
