School & Park Enscape Sketchup Render, any suggestion ?
I would random turn all trees and try use more or better textures, for example for grounds, grass, walls and roof. The grass color is to saturated … . ![]()
@mm3d.arsitektur I like the change of focus and perspectives. But I would like to see it in a higher resolution.
Alright thanks for your advice, i’ll try that
i’m using trees from asset library, i think it’s good enough texture ?
More I mean the ground, roof and walls are looking to homogeneous. The trees needs to be random turned only.
ohh, i forgot using jhs powerbar to do that, thanks anyway
