scotish pine forest
Another forest theme (yes i know im obsessed with nature)..currently workin on the greeneries..when im happy with it I’ll move on the house itself..critics r welcome :smiley:
gimmie some soft shadows on that grass!
Looking good already, but you always over sharpen so much. This only deteriorates picture.
thnks romullus..I always put sharpen at 50%..I guess I need to lower it down even more
Try to get abit of sunlight to hit the building and grass…hopefully some decent godrays would fit this image. Nice work so far
thnks yagi..im still adding details in the environment
Some updates so far. (for the pinetree scenery im aware that the foreground trees r sticking out cause i still have them in growfx format for quick adjustment if needed)
Great, Bryan!
doing something always is generally a bad approach, so far most of the shots I have seen of use didn’t any sharpen at all. You can add a touch for artistic reasons, but when you have jagged black lines around contrasted areas, it’s just stands out as an error in the image. Use it with care, rather than an automation.
