Screen capture / recorder?
I just wonder - have any of you tried to use a screen recorder to record an Enscape video? instend of setting up and rendering a movie?
If so - witch tool did you use? i’m trying Camstudio, but not sure it it’s ok.
Jorgensen
Hey @Jorgensen_dk , thank you for your post.
You may want to try OBS or VideoSolo to record your screen. I’ve successfully used OBS before to create some instructional Enscape videos. :slight_smile: If you run into performance problems, and the recorded videos turn out laggy even when using lower quality output settings in the recording software, you may also want to consider getting a dedicated capturing card, from Elgato for example.
thanks Demian
I will test them :slight_smile:
Jorgensen
I use Camtasia but it is more like a video tutorial recorder and editor. Besides OBS, you can also try Screen-O-Matic, Screencastify and TunesKit Screen Recorder. Screencastify only free for 50 videos.
Agree with @ciderpunk . Camtasia can seperate audio and video track and then edit independently. But as for a recorder, I prefer to use the screen recorder from Joyoshare teams. It is more easy-to-use.
