I’ve installed 3dsmax2021.2, and Corona 6.
When i start it, i get this script error : (see attached).
MAXscript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 2021\scripts\startup\CoronaRenderer_InitScripts.ms
Any idea ?
I would suggest manually removing both scripts from the root folder C:\Program Files\Autodesk\3ds Max 2021\scripts\CoronaRenderer and reinstall Corona, please let me know if that helped.
Removing the scripts may be one solution, but this should work too - see point 2 “setting heap allocation”:
https://coronarenderer.freshdesk.com/support/solutions/articles/12000019416
