Script for Converting max9 to max 7 ?
Hi does anyone know a script or methode to convert a max 9 file to max 7 without to much problems.
file consitsts of many instanced onyx tree´s as collapsed and instanced geometry objects.
And ! the Scene was produced with finalrender if i am not wrong.
any idea ?
Greetings Tom
You could always try with “Bobos file format”. It creates a script-file, which you run in Max 7.
Thanks, ill maybe give it a try, if my admin can reanimate any old version of max7
I’ve had best luck by using the latest versions of the FBX file format.. you lose some of the stack, but it transfers geometry and materials great from what I’ve tried so far.
Definitely search the autodesk site for the latest versions though. they update the file plugin quite often
