Script for mats
Anyone know of or have a script to change shader types? I need to find all ward shaders in a scene and switch them to blinn or phong. The infamous “red dot” problem.
Try the MaterialControl maxscript from the blur scripts collection.
http://www.neilblevins.com/blurscripts/blurscripts.htm
does not seem to work on VRay materials
Run zis and select all the objects you want changed:
Rollout changeBRDF "Change BRDF"
	global brdf = 0
	radiobuttons brdf_type labels:#("Phong", "Blinn", "Ward")
	button applyIt "Apply" width:200 align:#right
	on brdf_type changed state do
		global brdf = brdf_type.state as integer - 1
	on applyIt pressed do
		ObjArray = selection as array
		for m in 1 to ObjArray.count do
			if (classof ObjArray[m].material == VRayMtl) then
				ObjArray[m].material.brdf_type = brdf
createdialog changeBRDF width:300
Thanks! getting error though
-- Type error: CreateDialog requires RolloutClass, got: undefined
Piss. You on max 9?
Yar
Try this then - select everything and evaluate the code:
            ObjArray[m].material.brdf_type = 1
And for phong:
            ObjArray[m].material.brdf_type = 0
this should do the trick…“refs.dependson” is a killer for recursive stuff!
clearlistener()
fn removeward mat =
local mats = #()
local scenemats = refs.dependsOn mat
for r in scenemats do
	if (classof r == vraymtl) then
            append mats r
        join mats (removeward r)
	return mats
for t in scenematerials do
mymats = removeward scenematerials
for i in mymats do
print i
if i.brdf_type == 2 then (i.brdf_type = 1) else()
this script goes everywhere, no matter if your vraymaterial is inside a multimat,blend, whatever and how deep nested.
regards,michael
   global brdf = 0
try this to fix the error with the rolloutcreator
(additional wrapping parenthesis)
I’m still using max 8 over here (no reason to install 9 yet) so sorry I couldnt check :confused:
get the following error, for all of the above so Im not sure
if I am executing it incorrectly or error in the script
-- Syntax error: at ), expected <factor>
-- In line: )
oops, looks like i pasted the wrong code…
try this again:
clearlistener()
fn removeward mat =
local mats = #()
            append mats r
   return mats
for i in mymats do
print i
Sorry guys lost my PSU! Ok this works. Thanks so much.
