Thats really great, it works perfectly. I put the script on a ball, and removed it from all the peds. That script is now controlling the walk/idle of 10 peds perfectly.
Thanks you very much. I cant seem to get a 300k zip file uploaded on here for you to see, dont know why?
Here is the code;
MyArray = $Ped* as array
for i = 1 to MyArray.count do
t0 = f-1
t1 = f
p0 = at time t0 myarray.pos
p1 = at time t1 myarray.pos
if p0==p1 then WM3_MC_SetValue myarray.morpher 1 0.0
else WM3_MC_SetValue myarray*.morpher 1 100.0*
So all that is left know is getting the transition in the morpher to be over 5/6 frames, not “on/Off”
Probably something added on to the else WM3_MC_SetValue myarray*.morpher 1 100.0 line.*
Look into controllers and keyframes so that you can set a key at frame t (with t being the current frame) with a value of 0.0 and then at frame [t + 6] add a keyframe with a value of 100.
animate on (
for t in 0 to 100 by 5 do (
at time t
WM3_MC_SetValue MyArray[i].morpher 1 t -- the t variable is the frame time (0,5,10,15...100)
I have no idea what the variable f is or anything so your code doesn’t make any sense to me.
but try something like the above. I just can’t decipher this without some of the variable information.
