I have a few hundred models of massively varying size that id like to render thumbnails of.
I want to set up a basic scene and have max batch through them all placing them at origin however i would need the camera to zoom in or out to accommodate each object.
Anyone got any ideas of the best way to do this or even a better way than im currently envisaging?
Just select all your files in Connecter, then drag & drop to 3dsmax viewport. You’ll then get a contextual menu with several options, with one proposing to generate thumbnails.
Obviously, try that with only selecting 3-4 files, to ensure you’ll get what you want
It kind of works, however i cant figure out how to get it to show each object in frame.
It will only use the camera in the studio rig and wont zoom extents on the object
