Script thing
There’s a Swami-script I use from time to time called “Make Sign”. It creates a plane with the same dimensions as a bitmap that you select and applys a material with that bitmap to the plane.
I was wondering if it would be possible to modify the script so that the material it creates is a VRay material.
Here’s the script:
macroScript MakeSign
    category: “Uplate Stuff”
    internalCategory: “Uplate Stuff”
    buttonText: “Make Sign”
fn makeSign bm =
    rName =getFilenameFile bm.filename
    m =standard name:rName diffuseMap:(bmt=bitmaptex bitmap:bm)
    showTextureMap m m.diffuseMap true
    meditMaterials[1]=m
    r =rectangle \
                length: bm.height \
                width: bm.width \
                material: m \
                isSelected: true
    addModifier r (uvwmap())
bm=selectBitMap()
if bm!=undefined then makeSign bm
)-- end macroScript.
I tried changing the word “standard” to “VRayMtl”, but I got an error. Is it possible to make this work?
Thanks.
to
m = vraymtl name:rName diffuseMap:(bmt=bitmaptex bitmap:bm)
should work.. dunno
Thanks, but like I said, I tried that.
The error message I get is: Unknown property: “diffuseMap” in (material name):VRayMtl
---------------------Cut-here
fn makeSign bm =
m = vraymtl name:rName texmap_diffuse:(bmt=bitmaptex bitmap:bm)
showTextureMap m m.texmap_diffuse true
meditMaterials[1]=m
r =rectangle \
length: bm.height \
width: bm.width \
material: m \
isSelected: true
bm=selectBitMap()
-------------------------------end-cut
Thanks!
After putting )-- end macroScript. at the end it works great!
uh.. forgot the different map namings ..sorry!
