Max’s “replace” is very limited. I have couple of thousand instanced objects in my scene which I want to replace by a newer version. How do I go about doing that?
EDIT: Hmmm found objectReplacer in the Soulburn Script Pack - will give that a go and see.
if you replace thousand objects via maxscript it could thake some time cause
maxscript is not multithreading.
Here is a small script to replace objects:
macroScript gantmxs_replace category:“gantmxs” buttontext:“Replace Selection…”
on isEnabled return (selection.count != 0)
on Execute do
sel_arr = (for s in selection where s.parent == undefined collect s)
fn filter_geometry obj = obj.parent == undefined
global replobj = pickobject count:1 filter:filter_geometry
if replobj != undefined then
for i = 1 to sel_arr.count do
replobj.transform = sel_arr.transform
maxops.clonenodes (getobjchildren replobj) newNodes:&item cloneType:instance
delete (getobjchildren sel_arr*)*
if menuMan.registerMenuContext 0xf5e3905 then
(menuMan.findMenu “&Tools”).addItem (menuMan.createActionItem “gantmxs_replace” “gantmxs”) 19
menuMan.updateMenuBar()
much faster would it be to place Vrayproxys and only change the vrayproxy-meshfile.
