Is there any script sequence to be able to create a button that runs the Vantage Live Link launcher?
You can try running this script.
macroScript StartVantageLink
category:"Corona 12 Update 1 Vantage Live Link"
buttonText:"Start VLink"
toolTip:"Start Corona Vantage Live Link"
on execute do (
Corona.CoronaFp.vantageLiveLink()
messageBox "Vantage Live Link Started" title:"Corona Vantage"
macroScript StopVantageLink
buttonText:"Stop VLink"
toolTip:"Stop Corona Vantage Live Link"
on execute do (
messageBox "Vantage Live Link Stopped" title:"Corona Vantage"
fn printMessages = (
print "Corona Vantage macroscripts created successfully!"
print "To add buttons to interface:"
print "1. Right-click on any toolbar/ribbon"
print "2. Choose 'Customize'"
print "3. In Category dropdown, select 'Corona 12 Update 1 Vantage Live Link'"
print "4. Drag StartVantageLink and StopVantageLink to desired toolbar location"
printMessages()
Here’s how to use it:
- Run the above script in MAXScript editor (press F11)
- Paste the script and click the Execute button (or press Ctrl+E)
Now to add the buttons to your interface:
- Right-click on any toolbar in 3ds Max
- Click “Customize”
- In the dropdown menu labeled “Categories”, scroll down and select “Corona 12 Update 1 Vantage Live Link”
- You’ll see two new buttons: “Start Corona Vantage Live Link” and “Stop Corona Vantage Live Link”
Just drag these buttons onto any toolbar you want
I hope this helps.
I have logged this as an idea, hope we can get a proper Vantage toolbar or make the Original works in both engines
It would be ideal for the same bar to work for both engines.
vale, lo he arreglado y mejorado
global isVantageLinkActive = false --
buttonText:"CVLink" -- Nombre del botón
toolTip:"CoronaVantage"
on execute do (
isVantageLinkActive = not isVantageLinkActive
if isVantageLinkActive then (
if Corona != undefined and Corona.CoronaFp != undefined and isProperty Corona.CoronaFp #vantageLiveLink then (
try (
) catch (
messageBox "Error: Unable to start Vantage Live Link!" title:"Corona Vantage"
) else (
messageBox "Error: Vantage Live Link function not found!" title:"Corona Vantage"
) else (
on isChecked return isVantageLinkActive
