Hi, I like to render a few frams (3-6) and I like to clear the v-ray frame buffer after every frame and than keep to the next frame.
fn renderMe =
rendTimeType = 3
rendStart = 3
rendEnd = 6
max quick render
vfbControl #clearimage --------- (this line works only when the the render is finshed)
renderMe()
how can I apply vfbControl #clearimage affter every frame?
Won’t the Settings → System → Previous render set to “Clear” do that for you without the need for writing anything ? You can set it in the beginning of the script (renderers.current.system_previousRender=5).
Yavor
OMG! Cool! This work like magic!
How can I acsses all this properties on the Listner?
Thanks man!
As a rule in max, you can use the “showproperties” command to give you all the maxscript commands available for something in max. If you have an object selected in your viewports, you can use “showproperties $” and it’ll print out all of the commands (note this gets confused if you’ve more than one object selected), if you have an object in your scene called light001 you can use “showproperties $light001” whether you have it selected or not. For vray, since it isn’t an object you can select, you have to make sure vray is your current renderer assigned in max and then as Yavor mentioned above you can use “showproperties renderers.current” and it’ll give you all the info it can about whatever your assigned renderer is.
You are welcome
For the rest - what joconnell said
Thank you all!
The script is now redy and working nice!
