As the title states.
What can I send to help you diagnose?
Could you send over a scene sample to philip.shounev@chaos.com since I couldn’t reproduce the issue on my end in a newly created scene. Also a .dmp file (should be located in %temp% directory) would be helpful to spot the culprit.
Best,
Philip
sent! .
Thanks for providing the necessary files. I was able to reproduce the crash and made a note for our developers to look into (internal bug tracker ID: VMAX-13335)
pressing save image button while rendering in IPR also crashes max.
Latest nightly and max2024
We get loads of IPR crashes with th elatest vray releases…its very annoying
Regardless the scene complexity and dependance on other plugins.
We also had to redo every vray camera used in max 2023 scenes to new ones otherwise the IPR crashed max.
Vray unstable and frustrating. Especially when you start big scene that takes ages to load…hit IPR and bam…you can start all over.
Rendering without IPR works as expected.
Please do something with it. Thanks
Could you please elaborate a little more on the IPR crashes? I’m not able to hit the issue with neither saving an image to history nor the one with the cameras. An exemplary scene, perhaps a video showing the steps leading to crashes and a .dmp file would help us diagnose. If it’s possible, please send them over to philip.shounev@chaos.com for investigation. I would also suggest clearing 3ds Max’s ENU folder just in case.
