I am writing an own small shader to do some basic stuff and have one big problem.. I am calculation the diffuse, specular and ambient color in the eval() method and am returning the combined color.
That’s working fine and looks right, but as soon as I add some render-elements to get a specular pass for example, the result of my material looks wrong in this element.
But that’s right too, because how should VRay know about my specular-values? I am not passing them to VRay anywhere.. only the combined result color.
So, how can I tell VRay what color to use for the specular-element-pass?
V-Ray will automatically add the diffuse and specular results, but you must check the flags passed to BRDFSampler::eval() for the FBRDF_SPECULAR and FBRDF_DIFFUSE options, and just compute the required component.
And is there a way to write something to an own render-element?
For example, create a render-element called “Fancy stuff” and have my material put some fancy stuff in there..
Yes, you can do that. When you create a V-Ray render element plugin, you need to define an “alias” for it; after that, in the traceForward() method of your BRDF, you can write to this element in the following way:```
VR::Fragment f=(VR::Fragment) rc.mtlresult.fragment;
if (f) {
VR::Color someColor(0.5f, 0.5f, 0.5f);
f->setChannelDataByAlias(myElementAlias, &someColor);
umh, it was my fault.. forgot to assign the material xD
But do I need any special default implementation for the traceForward()?
Because if I just add the traceForward()-function in my code without anything in it:
void MyBaseBSDF::traceForward(VR::VRayContext &rc, int doDiffuse)
then my material looks a lot lighter (or transparent).. how comes this?
