Hi
I love to use VrayEdgesTex in my renders, especially with concrete, mixing it with noise or dent shader. I love what that does to the material, it’s an incredible effect (screenshot). But my problem is that the EdgesTex occupies the bump slot of the material. So if I want to use a strong bump map on the material, I have to use a Mix map to mix it with the EdgeTex. I make it 50/50, so I lose half of the effect of each map (screenshot).
Couldn’t you just make a second bump slot, both working at the same time at 100%? If we had that, we could also control them individually, maybe I want the edge only 10% strength and the surface bump 100% strength.
Or maybe I get the whole thing totally wrong?
thanks
Isnt that what a bump shader is for? Love the technique btw, will defo try that out, looks great!
I kind of see what is meant here, though could you not achieve the desired effect by e.g. setting the main bump amount to an abitrary high amount and making the mix variable to compensate one or the other?
I just woke up though, so maybe I’m dreaming this
I must be missing something…because it still sounds like a bump shader / bump mtl is the answer to me…layering bump maps on top of each other without compromising the effect of any by mixing maps directly, and having individual control over each layers amount.
So yes, I was half asleep, as that’d work exactly the same, just simpler
I haven’t even had breakfast yet…I should learn never to first look at this forum when I wake up
