Second Ocean Liquid Sim Does Not Render Mesh When Both Set To Ocean Mesh
I have two simulators with different ocean sims. Note the second one was copied from the first and then re-simmed with different objects, etc.
When I try to render both with Ocean Mesh enabled only the first liquid mesh renders. The particle shader work for both fo them, but I get splashes and foam floating in the air, and see none of the mesh for the liquid particles.
If I switch the second one to Cap Mesh then everything renders, but I think this is going to messed up in an animation. Aren’t all of the simulators supposed to be set to Ocean Mesh in order to blend them into the auto-generated Ocean Plane with the border fade?
The simulators do NOT overlap.
I tried setting oceanpriority of the first one to 100 (leaving the second still at 0). This did not help.
Anywhere I should look? I tried the latest nightly and it did not help. Max is 2023.
Thanks in advance.
From what you have described it should be working correctly.
Can you send us over the scene so that we can check what is going on? Can you also please attach a single cache frame?
You can submit the scene either here or if it’s not suitable for public sharing you can send it via the support portal.
Thanks!
It sounds like you’ve set up everything correctly. Yes, both simulators should use the Ocean Mesh mode to blend (in 3DS Max). And the one with the highest Ocean priority will be used as a material and a displacement source.
And it sounds like you set up everything correctly.
If it is possible, you can send a simplified version of your scene (or perhaps some screenshots of the settings), so we can investigate the issue.
Yeah, I will put something together for you in the next few days.
Given my particular shot it turns out Cap Mesh renders fine with no apparent artifacts. But even in Cap Mesh I was sometimes getting failures of some of the meshes to render.
I tried creating brand new liquid simulators and loading the caches. That seemed to work a few times, but then it started failing again with more than two simulators.
My current workaround that seems to work OK (at least with Cap Mesh) is to use Standalone rather than rendering with Max.
