SECTION CUTS NOT SHOWING HELP
hi!
im very new to this software and I did various section cuts in the model (I nested them also) to imitate a real life model. but I can only visualize 1 that is the one i did not nest , is there a way to visualise all the section cuts I did??? or is there a way to make what im trying to do? I want to render the image that shows the cropped model.
sory if my english is not as good, saludos de argentina!
There was a thread not so long ago that helped me with rendering sections. Apparently there is an issue with the GPU drivers and Enscape resulting to section cuts not showing in renders. They suggested to download a much earlier version of your GPU driver. Install it whenever you need to render sectioned perspectives then reset to the latest driver when you are done. Although I am not sure which version of driver as I have forgotten it. WIll try to search for the thread and reply back as soon as I am able. You can also use a paid extension called Skalp.
No you can only have one section cut in Enscape. Even if it is or isn’t nested.
