See what material an object has
Is there a quick way to see what material is assigned to an object? Sometimes just looking at it isn’t enough.
@jvparc
I think the attached is what you are after. “edit vray material”. Click that icon, then the item.
Glenn
Hi @jvparc ,
What Glenn mentioned is exactly right!
And the other way around - going in the Asset Editor and right-clicking on a material, there is a ‘Select Object In Scene’ option.
The material name can also be seen at the Rhino object material options.
Thanks everyone --- the material wasn’t showing up in the Rhino object material options for some reason, that’s what was throwing me off.
