Hi There,
anybody know of a script that can select all objects in scene with no materials applied to them?
regards,
Wim
Hi There,
regards,
Wim
Just happen to have a small script that does just that. We use it when working with Revit files as a quick way to grab anything that doesn’t have a material already assigned.
Installation: Maxscript / Run script. Find it in the category “CG_Tools” in Customize / Customize User Interface.
Usage: select objects and it’ll only select those within your original selction that don’t have a material or run it without anything selected and it’ll look for objects in the entire scene (hidden/frozen/etc) that don’t have a material.
Sel_Select-Objs-Without-Material.zip (841 Bytes)
Excellent! thank you!
easy!
clearSelection()
for o in objects where isProperty o material do (
if o.material == undefined then
selectmore o
The above line by line means:
clearSelection()
- Clears the objects you currently have selected in the scene
- the word “objects” is a reserved keyword referring to every (selectable) object (node) in the scene (cameras, lights, etc), where “o” refers to each of those objects
- isProperty o material checks that o.material (o being one of the objects in the scene) exists, so obviously cameras and lights will not meet this condition so they won’t be selected, this sets up the call to o.material (which would error out if you had a camera selected and did $.material, because camera’s don’t have a material property)
- Checks to see if the material is undefined (referred to as NULL in other languages)
selectmore o
- If you use “select o” then the script will complete and the last object that had no material applied would be selected and not all of the previous ones
- Terminates the for loop
Hope this helps
instead of the “objects” set you can use “geometry”,
here is my version that i’m using all the time:
clearSelection()
for i in geometry where i.material == undefined do selectmore i
Problem with the above script is it won’t get renderable splines without a material, which is why I wouldn’t use “geometry”. Geometry only uses objects defined under the geometry subclass, which renderable splines wouldn’t be even though they can be renderable geometry.
And I’ll amend mine to the following so it won’t select cameras and lights (which I just checked have a material property)
clearSelection()
for o in objects where (isKindOf o shape and o.render_renderable) or (isKindof o geometryClass) and o.material == undefined do selectmore o
Ah, OK…didn’t think about editable splines, since I never use them.
Probably both versions have their place.
Thank you!
and thanks for explaining the script.
regards,
Wim
That’s exactly why I hate MAXScripting, everything is so damn complicated. The way max handles BitmapTextures is absolutely ridiculous and makes no sense why it can’t find them in displace modifiers, environment tabs, etc. You just have to hack your way around it like crazy. Oi. I love programming, but seriously max, re-write your stuff so it makes some sense, stop adding features to maxscript when the whole system was built in max 3.0…
-Colin
