Select by Material - Broken
I have been using 3ds max 2025 and V-Ray for my usual texturing and rendering. I downloaded 3ds max 2026 last week. I am facing an issue whereby when I select a material in the material in the material editor, right click, then select by material, nothing is selected.
I have tried opening other existing models I have produced, that have previously worked fine with this workflow, however when selecting by material, it keeps selecting a single random object that does not have the sampled material applied.
This is affecting my workflow, as I solely use the select by material to quickly change materials etc.
Please help, Thanks
I can confirm this, its happening with Corona too, maibe this is something from 3ds Max but I have seen bugs comming from plugins.
In the meantime @Neil_FD you could give it a try to this script thatt someone shared to me in “Stack” Facebook Group
https://www.facebook.com/groups/stac…49006872112461
You could also give it a try to this : https://www.youtube.com/watch?v=mE-3uNWL3eo
Happens in Arnold/Scanline, too. It’s surely an Autodesk issue.
Autodesk borking features that have been working for 20 some years again. Standard.
As not everyone has Facebook I’ll also upload the script here. All in all I find this script handier than having to open material edtitor, "get material’, select by material, OK. This script is a lot faster and works with multiple objects with different materials.
DigitalTwins_SelectObjectByMaterial.zip (752 Bytes)
Thanks Vizioen for the script. I thought I had bad file import practice but the issue appeared also for me for totally homemade model. I can confirm the issue also happens with standard Physical Materials. Very annoying.
@titan_contact its a 3ds Max 2026 bug Confirmed from Autodesk, its an issue caused by an update to Vault that its affecting not only Select by material but another tools too:
"Unfortunately, an update to a Vault/ DevExpress component broke this functionality in the Scene Explorer code. This also affects a couple of other functionalities such as Select By Name in XRef Objects and Unhide By Name.
I’ll stick with 2025 for now. What a mess.
Exactly, I always start using the new version until I have all Plugins installed (the only one thats missing from my workflow is tyflow, which now that im seeing it has been updated yesterday btw), and of course I dont uninstall previous until I have noted that everything is running ok.
