Select objects in scene
Hi everyone,
When i use (select objects in scene) function in VRay 7 by material and want to change those objects to something else, then it also changes materials on all the objects that are on other layers and also if they are hidden. It very frustrating because i do not want to change the material on all the hidden/invisble objects, only the visible. This bahavier is new, it did not do so in VRay 5.
Is there a way to select all objects visible by material? I hope it makes sense.
I use Rhino 8 with VRay 7
