Is there a way to select the light mix list item by light? You know, On the contrary, we can do it. I want to do that in Maxscript or C# .
You can reference this post about the lightmix, which has valuable information on scripting the lightmix:
https://forum.corona-renderer.com/ Maxscript access to LightMix
From that post I put this together for you, you can also use more loops to do other stuff but the basics are here. Its a bit quick so you can clean it up for your use but you should get the point:
coronaLights = #()
for i in getclassinstances CShading_LightSelect do
-- Adds array, eg Light_Select 2 might have 3 lights, etc.
append coronaLights i.includedNodes
-- select the light in the first Light_Select - 1 light in this array
select coronaLights[1][1]
Also if you want to select all the lights in say Light_Select 2, remove the last line (select coronaLights[1][1]) and use this instead:
--select the lights in the second Light_Select - 2 or more lights in this array
lightSel = for j in coronaLights[2] collect j
select lightSel
Or just have it do multiple for loops, like for i in coronaLights for j in i etc..
Well I dont know how to access the UI but you can use this instead, select a light and run this script, it will give you a messagebox with the Light Select Elements name:
-- Struct to hold LightSelect Element and Lights associated to that Element
struct LightMixData
elementName,
lights
-- Add the Lights & Elements to the Struct
lightMixTable = #()
lightMixEntry = LightMixData()
lightMixEntry.elementName = i.name
lightMixEntry.lights = i.includedNodes
append lightMixTable lightMixEntry
-- Messagebox to show user the light element for selected light
fn ShowMessageForSelectedLight =
-- Get the currently selected nodes
selectedNodes = getCurrentSelection()
if selectedNodes.count == 0 then exit
for node in selectedNodes do
if isKindOf node Light do
elementName = for entry in lightMixTable where findItem entry.lights node != 0 collect entry.elementName
if elementName.count > 0 then
messageBox ("Element Name: " + elementName[1] + "\nLight Name: " + node.name)
else
messageBox("Element Name not found for: " + node.name)
-- Run Main Function
ShowMessageForSelectedLight()
Edit:
I think access to Lightmix via maxscript is currently in development (by user request). Once this is rolled out we should have access directly to the value/color in the lightmix which would be great because we can extend this script and build a little UI so when you select a light you can directly change properties in the lightmix as needed.
