Guys, I need your help!
I have a complex scene that i created in 3ds max 2018 and corona 5, then I upgraded to 2020.2 and now I need to return to this scene and continue working.
The problem is - when I open this scene in 2020, 3ds max just crashes. I can merge all the stuff into a new scene, but after saving and opening 3ds max continues to crash. Empirically, I found that it was Corona render, because when you remove Corona render completely - the problem disappears.
Alternately isolating the layers and “save selected” to new separate scenes, I found out that the problem concerns objects, the materials of which contain a distance map.
And now i need to find all my objects with distance map. Unfortunately I dont know the MAXscript and therefore I need your help, plz)
The only good thing about a crash is that it creates a minidump, which lets developers see what was happening at the time. For any crash, please always send us the minidump (here, or by private uploader) - see https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006-how-to-report-issues-3ds-max for info on how to find the minidump, the private uploader if you want to use it, etc. (Though it doesn’t help with finding all the objects, it could be something that we need to fix in Corona itself, so the minidump would be helpful )
You absolutely need to supply the scene or something that displays the same problem to the Corona staff, they will probably be able to identify the problem quickly. Or minidumps created with the crash. You will do a favor to the entire user base as this should simply not happen ever.
