Not sure if this is a bug but i find that with Corona 3 the selecting of camera’s is inconsistent.
Sometimes it will take up to a second for the camera object to be selected. It’s not instant like other native primitives.
Strange thing is that it’s not all of the time and I don’t know how to recreate it.
Empty scene no other software and it sometimes still occurs.
Anybody else got this behaviour?
I found that when adding a standard physical cam to the scene the other cams get their responsivness back.
However it will get laggy again at some point.
As far as i recall, bigger or smaller lag was always present when selecting Corona camera. Maybe not up to second, but definitely noticeable.
Well I’ve never noticed any lag and as I told before the lag is not always present.
What you see could be related to whether the command panel is in create or modify mode. In the latter, the camera’s UI panel will build up which can take 1 or 2 seconds, making it feel like the camera is slower to select. In create mode it doesn’t display any UI so it’s going to be instant.
