Selecting Objects with Physical Materials
Hi all
I need to bring a scene into Twin Motion. I have a script that converts Corona Materials into Standard. It seems to work but doesn’t work on Physical Materials.
Can anyone give me a line of code or something to select objects with physical materials so we can work on those?
Or, even better, modify this script that I’m using to make it work with Physical :
https://www.scriptspot.com/3ds-max/scripts/corona-material-to-standard
Any help would be great.
Thanks,
Sean
You can try using this modified script, based on the one from script-spot.
It should convert only CoronaPhysicalMtl-s to Standard materials.
It has the same functionality as the original script.
Hope this helps.
CoronaPhysicaltoStandard.ms (1.2 KB)
