Selecting Proxies
Hello everybody,
I started to use proxies more and more (since a viewport-slowing issue was finally fixed). I’m having trouble now with selecting proxies in the viewport. I attached a video, showing all combinations of visualization method, selection tool and viewport mode.
The easiest to select is solid bounding box, the worst is point cloud. When positioning objects I mostly work with full mesh, and that you can only select when you click near the pivot point. And usually there are more objects layered.
Anything that I a missing? Nobody else experiencing this?
Full-speed non-debug version
Build timestamp: Nov 27 2019 20:53:52
Version: 5.0
Cinema version: R21.207 Cinema 4D (single-license)
Looking forward to your answers.
Best,
Ararat
PS.: I also would love if the Corona Proxy object automatically takes all the materials and object names of the original one. This could save some extra steps!
Hi Ararat,
I can also confirm this. Thanks for reporting!
(Internal ID=498714333)
Hi Beanz,
this issue wasn’t fix in version 6, was it? Any update on when it will be fixed? I am not using any daily builds.
Build timestamp: Aug 25 2020 09:52:16
Version: 6.0
Cinema version: R21.207 Cinema 4D (mutli-license)
Thanks,
Ararat
