Separate physical sun and sky in maya
Hi, Please could someone help?
I really need to separate the Sun from the Sky colour in Vray 2.0 for maya is this possible at all? - I just need the colour to change independently from the sun direction…
Massive thanks,
Joe
Sure, there are several things to do; one is to pipe the sky texture through a suitable Maya utility node (HSV etc) before connecting to the V-Ray Environment slots. If you want to use a completely different sun direction, then you can simply clone the V-Ray Sun, disable the sun light connected to the sky so that it does not illuminate the scene, and use the copy to do the actual illumination - see the attached scene.
separate_sun_sky.zip (8.03 KB)
vlado, you’re a legend!
Thanks so much :slight_smile:
Joe
