Currently the only way to blend the color corrected pass with the original RGB in post is to save both files out manually.
You might try saving out a LUT and then blending the LUT in post. But the LUTs out of the VFB aren’t perfect.
you could use the Composite mode:
https://ftp.chaosgroup.com/support/screenshots/3dsmax\_2024-05-20\_13-10-33.gif
Right, exporting the LUTs and loading them up in photoshop doesn’t give the same result unfortunately.
