i’m encountering some really odd behavior.
Guess you should even be able recreate it easily or something is broken my setup.
Fresh empty Max Scene,
Create LiquidSim Container,
put a Sphere in the middle of it, not moving,
Hit sim, setup starts to turn crazy …hhhm why? do i miss something obviously right now
Would be great if you can have a look at that as this situation puts me to a grinding halt!
Btw, i’m having this issue since the latest two nightlies, at least that was when i became aware of.
Have to add:
It doesn’t make a difference if the sphere is set to “clear inside” or not.
Pretty much everything in the liquid sim is on default as i made a new scene for it.
As scale also seems fine, I don’t even have a clou right now what is causing this odd behavior
The Max version shouldn’t matter… How many CPU cores do you have? What if you reduce them to 12 or 8 in the Simulation rollout? Does it make a difference?
Will do a screengrab so you can see better.
But already looks like reducing the threads don’t make it better
Also when i turn on splashes and foam they spill with crazy speed, do i remember right that there should be no splashes under water? Remember the floating boat issue i had?
Ah yes, this is not something new, I rolled back as well.
What settings you used for the animation in your previous post tho? I see the result, but can’t say anything because I don’t know what the settings are..
Oooookay, but did you try my suggestion to raise the steps per frame or the scene scale?
If it doesn’t happen with the box, then this confirms my guess that it might be related to the pressure in voxels which are partially occupied by obstacles. If you rotate the box at an angle, maybe the air pockets will start showing up?
If this works for you as a workaround for now, I will try to check the suspicious pressures over the next few days and will ping you when I have more news - maybe this can be improved in code without needing to raise the SPF too much…
