Serious Performance Issues - Nvidia Drivers 511.09
I have re-rendered a scene which on the older drivers took about 21-22 mins. On these 511 it took about 30 mins. Also I have monitored the whole render process with GPU-Z and I haven’t noticed a GPU downclock and that’s why I have uploaded a GPU-Z Sensor Log.
I know the issue is not an easy one but reading on lots of GPU forums more and more people are complaining that this branch of drivers (512.15) are simply lowering fps in lots of graphics and rendering programs and games too.
Vasile B.
GPU-Z Sensor Log.txt (1 MB)
Thanks for the data. We’re in contact with nvidia and trying to get to the bottom of this. It looks like there may be two separate issues - yours and the one described by Muhammed where the clocks change.
We moved the recommended driver to version 512.59, it is much better in preventing the issues we came across (at least on our side) and you still need high performance mode in Nvidia’s control panel.
If you are still getting this behavior, you are the only one that complained about it(without the GPUs downclocking) we cannot help much in this case(unless I take a look at your settings and your setup through remote access)
Best,
Muhammed
@vasile_bulgac1 have you tried if the issue is present with 512.59 or 512.77?
I have installed yesterday SD 512.59 drivers on my 3090 machine.
Unfortunately same results. Can’t get past 25-30 FPS in high res renders (eg. 4320p). Lower resolutions are fine up to 2160p.
On the other hand on my machine with A6000 I have noticed a slightly perf increase 1-2% but still not as good as 472.98.
