I downloaded the serv pack 2 for max 2008 for the 64 bit version, ran the install and it siad that it needed to uninstall the old serv pk first. it did this but then gave me a message saying that not all of the vray was uninstalled and some needed to be unistalled manually. it finished. I statrted max 2008 and it gives me this error.
“DLL<C:\Program Files\Autodesk|3ds Max 2008|Plugins|vray plugins|vray
> symbiont 90.dlt> failed to initialize error code:14001- the
> application has failed to start because it’s side-by-side
> configuration is incorrect. Please see application log.”
I ran the install twice now and no change and i have no idea what to manually remove. Any suggestions?
mh
i deleted vraysymbiont.dlt which solved the error message. Now i have installed the microsoft visual c++ stuff. Did i make a mistake deleting the vraysymbiont file?
mh
" mikeh
What is better to do is just rename the file, like adding <.off> as a new extension.
So if one day you install the DarkTree shaders, you can start using the VRaySimbion material
for it.
