server error
Hi all,
I tried to use a computer which worked fine till few weeks ago, as a server, but now it gives me an unexpected error, once the vray consolle is loaded.
The vray versions match (1.5 SP3), and the network locations are fine.
I can render on my station, same settings and everything, but not on the slave.
Could this be some network security feature that stops Backburner from communicating?
I do see the slave, and the job does get transferred though…
Thank you
regards
Gio
Which 3ds Max version are you using?
