So I think my last thread was in 2005 so bare with me…
I started on Max in Dos then I migrated from Max 5 to Max 8 to Max 9 (vray SP2) and now at 2009 (vray SP3) recently and have been getting the same problem on old and new files. With the older files (max9) it’s a matter of setting the threads back to 0 and adjusting some settings to make it perform and look as before but what I keep getting is the host servers not responding after working on the file long enough. I’m basically doing DR and then I’ll do something that just kills DR in that file. It happens when I restart the rendering after I tweak something. As soon as that happens I try all sorts of madness. Restarting every service everywhere, resetting max, re-openning but too late no more DR in that file unless I reset, start with a blank file, merge in the model from the corrupt file, adjust everything back then hit render using DR and it works again! I also try using a DR scene that is very simple and it works fine. Load the corrupt one and it doesn’t. Never happened with SP2. The worse thing would be you had to restart the service and it worked.
The way I know it’s busted is when I hit render and it gets to
Scene transferred to buckwild (one of our render nodes)
but no Server status proceeding that. I just get the local computer rendering then a green error that the node stopped responding.
Before I posted this I spent a few days on the forum and on several projects trying to figure this out. Hopefully someone can point me in the right direction. I can send files if necessary
Thanks!!!
PS there are no other max versions on any of the computers.
FILE
Max 2009
Vray SP3
usually around 8-20megs
WORKSTATION
Windows XP 32
Dual Core 4GB
Max 2009
Vray SP3
running vrayspawner
running VRLservice
No firewalls
HOST SERVER
Windows XP 64
Quad Core 8 GB
Max 2009
Vray SP3
running vrayspawner service
No firewalls
