Set env maps as Rhino background
it could be great to get this functionality for VfR too. For each env option an own button to choose a file (automatic set as Vray env map) and set it as Rhino background.
Micha
Hi Micha,
do you manage to control your exposure from environment slot and not from the physical camera ?
If that works, it would be great what you propose here. My wish would be if same texture can be by default proposed by vray when calling Texbitmat in material editor and dome light!! That would save so much time..
Never I use the exposure control from the physical camera, because I want to adjust the DOF without to fiddle about the render brightness. So, I use the env map multiplier.
Yes, it would be great to get a way (for example per right mouse button on the map symbol “M”) to synchronize VfR and the Rhino viewport.
