Set focus distance issue on Vray RT
this option doesn’t work for me and crashes the RT CUDA render
regards
I tried to reproduce this problem here but it seems to work in my tests. Do you get crashes in any scene or is it scene dependent ?
If it is scene dependent - can you share one such scene here or with our support ?
Yavor
Btw, keep in mind that DoF is support in V-Ray GPU when using Physical Camera only.
Best,
Blago.
At the moment I’m testing Vray 3.50.04 on Max 2014, don’t know what happens with Max 2017.
I’m using a simple scene with basic Max primitives to check if everything is ok.
Pointing the cross over one object a clicking the rmb the renderer does nothing. Clicking several times the Cuda renderer exits and shows a message error.
I’m using Nvidia driver 376.53 (the one updated automatically by Windows 10) I can check with the latest Nvidia drivers on other machines.
regards
HI,
you mean the latest Max physical camera? not the vray physical camera?
You have to render through Max physical camera or V-Ray physical camera.
I tried with V-Ray 3.50.04 on Max 2014 but still couldn’t crash it. Could you share your scene (however simple it is) - maybe I’m missing something.
