Set up Depth of field
Hello
I’m having some problems with regulating the depth of field.
Even if I change the focus distance the depth stays the same.
Anybody can help me?
Thanxx
Could you show your setup and maybe your result? DOF in Corona works exactly the same as with real world cameras - smaller aperture (higher F number) and longer focus distance gives wider depth of field and vice versa.
What kind of camera are you using, and how are you changing the focus distance?
Is DOF staying the same in IR only, or also in regular rendering?
