Hi There,
Loving the new Chaos Player! I have a question - how can I set any personal defaults? For example it would be great if I could set the Colour Mapping --> Colour Space to default to sRGB, or the zoom level to “Fit to Window”, but I don’t think this is currently possible. Assuming that’s the case, are there any plans to add custom default settings?
This is currently not possible, you are correct.
Some settings have a right-click option to use the current value as the new default, but that doesn’t apply to color mapping and the ‘fit to window’ options.
We do have plans to make this possible, either with a settings window or just adding a ‘use as new default’ to those options, depending on how we move forward with other tasks.
The last few updates have an option to set a preferred color mapping per file type, so this part was added.
We still haven’t been able to do this for the fit-to-window option, though, apologies.
I hope this helps. Here’s a link to the update video where we show how you can specify per-file-type default color mapping.
