Setting problem
everytime i open visual setting or general setting, this message always pop up.. and when i close this pop up, my sketchup force closed
how to fix it please..
thank you before
Thanks for your report and welcome to our forum @pramusesa , could you please uninstall Enscape and re-install it once more this time for all users? You can select this option by just running our installer and then → briefly accept the License Agreement → Next → Advanced →
In case this doesn’t help, could you also please contact your system administrator (if there is one) that he makes sure you’re having access the mentioned path in the error message?
I had the same problem. I’m pretty sure it is installed in “all user”, but the problem still cannot be solved.
I am sorry to hear about that - so you still experience this problem? Can you please also contact your system administrator so that he can make sure you’ll have the required read/write rights?
