I’m using Rhino 8 / Vray 6.20.04 / Python 3 to render images with different settings in a loop. Everything works fine with one exception. The code
import rh8VRay as vray
# the next commands are called in a loop with varying values of angle_degrees
plg = vray.Scene.Plugin("/Environment Bitmap/UVW#1")
vray.Scene.BeginChange()
plg.rotation_h = angle_degrees
vray.Scene.EndChange()
vray.RefreshUI()
updates the respective value in the Asset Editor but the updated value gets ignored by a subsequent render run. Only values for “Texture Placement” > “Rotate H” that have been manually edited in the Asset Editor are taken into account by the renderer..
Is there an explanation (and possibly a solution) for this behavior?
now calculates a HDR file whose pixels have been moved according to the required rotation. The rotation is performed around the vertical axis (yaw); if an addtional rotation around a horizontal axis should be applied the code would get a bit more complicated, but the principle stays the same.
Before each render call the image gets loaded into VRay’s options with
the reason you see a change in the UI but not in the scene is because the UVW’s parameters are not direct scene parameters.
In other words. changing the rotation_h is display-only property, it is not a scene parameter. The actual parameter in the case of the environment texture is called UVWGenEnvironment.uvw_matrix
When you change the rotation from the UI, the UI takes that value and calculates the full transformation matrix, then only stores the value for display purposes. This was done long time ago, due to rounding errors when the value us pulled out from the matrix.
Furthermore rotation angles (so called Euler angles) in a matrix are not completely recoverable. You loose the 2pi multiple and/or the sign (for 3D transformations).
This is one really legacy thing, and it is on the roadmap to do a proper handler on that.
if you need some help with constructing the final matrix, let me know
